Bathroom sink faucet
White Tiger
I have a peerless faucet in the bathroom sink that has a continuous drip.It seems to be on the hot side,it is a two handle faucet and I would like to know what tools and repair parts I would need.Any help would be greatly appreciated. THANKS!:confused:
Brownizs
Springfield, IL
Towel, Phillips head screwdriver, and a Crescent Wrench. Just remember to shut off the water before removing the valve stem. Once out (might as well pull both), replace washers & gaskets, then reverse process. Your local hardware store (ie Ace Hardware) will have the parts in a nice little packet for that particulare stem.
faucet
That faucet is a rebranded Delta faucet, so you use Delta parts. It probably has the all plastic stem which warps on the bottom. buy the seat/spring repair kit, and two new stems with the stainless steel bottom plates. When you remove the handles make a note of location of the raised handle stops, so you can install the new ones the same way, or the handles will turn backwards to open and close the faucet.
