Bathroom Sink drain pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TallyDIYer, Mar 16, 2009.
  1. TallyDIYer
    TallyDIYer New Member
    Mar 16, 2009
    Real Estate Appraiser
    Tallahassee, Florida
    Hey guys. I've spied your site before but this is my first time joining and posting. I'm putting a new bathroom sink in that will be open underneath. My wife and I want to change out the trap pipe thats been there forever with a better looking one (no PVC either). The existing P trap (I believe that's the correct term) appears to be within a copper fitting right at the tile wall. I need to know how to remove it so I can put the new one in.
    The old one is too short and also very ugly, otherwise I would leave it alone. See the picture below. I tried to pull the pipe out with channel locks and slightly dented it.
    [​IMG]
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    No picture, but it may be soldered in.
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    That is called a solder bushing. It threads into a threaded fitting in the wall and the trap arm is soldered into the bushing.
  5. TallyDIYer
    Mar 16, 2009
    Thanks guys. Do you think I can turn that coupling and unthread it then heat the coupling to remove the P trap and put in a new one?
  6. C NUMB
    C NUMB Plumbing Contractor
    Jan 13, 2009
    plumber
    NPR, FL
    That actually looks like a hub of a DWV brass fitting with a sweat bushing for the trap. You would be better off trying to un sweat that.
  7. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I would first verfiy you have iron or steel pipe in the wall if it is copper dwv, then that fitting is sweated in place as well. If there is threaded iron pipe in the wall, we normaly cut the trap arm off then use a saw to cut the brass fitting out of the iron pipe threads. Then install a male brass trap adaptor in its place.
    [​IMG]
  8. hj
    connection
    The picture is too out of focus to tell what you have there. It does not look like any solder bushing I have ever seen, (there does not seem to be solder between it and the trap's arm), nor does it look like a regular slip joint connection.
Similar Threads: Bathroom Sink
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Yesterday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink - Popup - No Through Pivot Rod Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Sink Stub Out Too Close. Jan 24, 2017
