Bathroom remodel
Discussion in 'Shower & Bathtub Forum & Blog' started by CHAPSKIP, Nov 7, 2007.
  1. CHAPSKIP
    CHAPSKIP New Member
    Nov 6, 2007
    Is it okay to install a prefabricated shower over ceramic tile. Also, how would you install a marble threshold to transition from ceramic tile to carpet. Should it be installed on cement board or the subfloor which is plywood. Which type of adhesive should I use?
    thanks for help,
    chapskip
  2. jadnashua
    The pre-fab bases require a flat surface. If the existing tile was a floor, and not an old shower, then it should be flat. It also requires level, so check that. If it was an old shower you are hoping to reline, not a good choice.
    While you could probably put a marble base directly on plywood, it would probably be better if it was over cbu. Thinset or a medium bed mortar would be the best choice. You want all the minor imperfections filled in so it is 100% supported, and gluing it down isn't likely to do that. Mortar will.
Similar Threads: Bathroom remodel
Shower & Bathtub Forum & Blog Bathroom Remodel Help Jan 29, 2017
Shower & Bathtub Forum & Blog Small bathroom - non-standard size tub remodel Mar 22, 2015
Shower & Bathtub Forum & Blog proposed subfloor removal for bathroom remodel Dec 15, 2014
Shower & Bathtub Forum & Blog $14k - Completed DIY Bathroom Remodel Aug 31, 2014
Shower & Bathtub Forum & Blog Small bathroom remodel.. Aug 30, 2014
