Bathroom Remodel - Toilet Drain Lines
Discussion in 'Remodel Forum & Blog' started by ptl_10, Aug 9, 2005.
  1. ptl_10
    ptl_10 New Member
    Aug 9, 2005
    FL
    I am in the process of remodeling an upstairs bathroom. I want to relocate my toilet and this will require running a 3" pipe through my 2" x 10" floor joist. Here is a picture of the floor and where I would like to place the toilet http://home.earthlink.net/~ptl_5/ and the 2 different options for routes I have for running the drain pipe for the toilet. Route "A" would require drilling through 3 floor joist and the middle of the hole would be about 6" from the end of the joist. The other route "B" would require putting a hole where there are 3 joist together. Any help or comments would be great. Thanks.
  2. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    "A" looks a lot safer to me... but I'm not plumber nor structural engineer....
  4. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    any room underneath to build a soffit?
  5. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    I would go with plan "B", one hole to drill and be done with it. Also I would cut a couple of 2x's and sister up the old hole on each side.
  6. ptl_10
    ptl_10 New Member
    Aug 9, 2005
    FL
    Currently there are no holes in any in the floor joist.
  7. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    Oh okay! Looking at the picture I thought the 3" wye was picking up the existing toilet and it looked like it went thru the joists.
  8. sulconst2
    Jul 11, 2005
    remodeler
    old bridge nj
    if no room underneath for a soffit. i'd go with plan b.
    set up your pipe, drill the hole, then make a cardboard template of the hole and the 2x10. take it to a steel yard and have a 1/2" flitchplate made with staggard holes for bolts. install this first then your pipe.
    this is whats done in jersey to pass frame inspections if large holes are drilled in bad spots.
  9. ptl_10
    ptl_10 New Member
    Aug 9, 2005
    FL
    Its hard to tell from picture but the original set up goes under the joist.
  10. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    If your'e joist are 16"on center then it looks like you would be moving your'e toilet about 4', which would equal 1" in pitch. If this is the case then you would only have to notch the bottom of them a very small amount which wouldn't effect the strength of them.
  11. ptl_10
    ptl_10 New Member
    Aug 9, 2005
    FL
    The joist are 16" on center and yes I would be moving the toilet about 4', there is a drop ceiling where all the plumbing currently is about a foot under the joist. I do not have this drop where I would be relocating the toilet toI would have to run through the joist and down where the current toilet drain is.
  12. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    Ok, because you would have to offset the 3" up to the joists for the new location you will also have to install a vent for the toilet.
  13. mixdenny
    mixdenny New Member
    Jul 30, 2005
  14. ptl_10
    ptl_10 New Member
    Aug 9, 2005
    FL
    I have a wall right behind where the toilet is and I was going to run that drain into the toilet using a side-inlet elbow which would provide the vent.
  15. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    Side inlet elbows are not allowed here. You would be better off leaving a wye just before your'e closet bend.
Similar Threads: Bathroom Remodel
Remodel Forum & Blog Tiny bathroom remodel Aug 28, 2016
Remodel Forum & Blog Herb's Bathroom Remodel Jun 27, 2015
Remodel Forum & Blog Bathroom Shower Remodel Jul 5, 2014
Remodel Forum & Blog Bathroom remodel: underfloor heating and related decisions May 13, 2014
Remodel Forum & Blog Big problems arise after bathroom remodel: advice needed May 8, 2014
