We noticed water stains in downstairs bedroom ceiling directly below the upstairs shower. I removed enough damaged ceiling wallboard to notice water coming down along the vertical copper feed pipe when the shower was turned on. Strangely, it also drips along the same route at the same rate when the (separate) tub next to the stall shower is being filled. (I recently replaced the shower valve cartridge as it was getting very hard to pull/push to turn on/off.) Are the tub and shower leaks separate problems or could they be related? I'm suspicious of the valve cartridge since that's the only changes made to the system but don't understand how that would be related to leaking when the tub water is running. Any ideas?
Mikal
Mikal
