Bathroom DWV Layout
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by handyman923, Jul 5, 2012.
  1. handyman923
    handyman923 Member
    Nov 20, 2006
    Portland, OR
    I am putting a small addition on the back of our house with a new bathroom. I was hoping I could get some reviews of my DWV layout. It is a simple bathroom with the vanity, toilet, and tub/shower.
    Originally I was going to use a horizontal wet vent, but my plumbing inspector told me that the toilet has to be the first fixture, so I am stuck venting each fixture.
    I am in Portland, Oregon, so we use the UPC.
  2. Terry
    Aug 17, 2004
    Here is a nice link to Bert Polk's plumbing tips
    You could wet vent the lav over the toilet if the trap arm is within 42".
    I would run the tub in 2" until you take off for the trap arm.
    Fittings below the flood level need to be drainage, not vent fittings.
    [​IMG]
  4. timf
    timf New Member
    Nov 2, 2011
    Oregon
    I’m not a professional, but a few thoughts and observations…
    1) Venting all the trap arms like you show is good
    2) For the lav and tub, although maybe not required by code, I’d consider 2” drain lines
    3) Off the rolled wye on the toilet vent (if rolled 45 degrees), I think the 45 you show may need to be a 60
    4) For the toilet vent elbow, use a long sweep 90 where the vent goes from horizontal to vertical
  5. handyman923
    handyman923 Member
    Nov 20, 2006
    Portland, OR
    Thanks for the feedback...
    I have changed the fiitings below the flood line to all drain fittings. I like Terry's idea of using a wet vent for the lav, but I think it will probably be over 42". I'll have to play around with the 45 or 60 at the rolled wye.
    I have updated my sketch and highlighted my changes.
    Thanks again!
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The vent for the toilet MUST rise vertically until it is 6" above the flood level rim of the highest fixture served which in your case would be the lav so, that flat section between the rolled 45 and the elbow can NOT be flat.
  7. handyman923
    handyman923 Member
    Nov 20, 2006
    Portland, OR
    What defines vertical? Is it 45 degrees to the horizontal or more? If so, maybe I can slope that flat section up until I get into the wall.
  8. Tom Sawyer
    Nov 29, 2010
    Maine
    It has to be at an angle of 45 degrees or more
  9. goat
    goat New Member
    Sep 14, 2013
    NC
    hi terry, that's a great link '' Burt Polk's plumbing tips '' you think you could list some more comprehensive links relating to drain and venting coeds, I live in NC, if it matters.
  10. goat
    goat New Member
    Sep 14, 2013
    NC
    I'm new to forums so my formatting and ability to display images is poor. But I'd gladly take advice from anyone with coed abiding plumbing advice particularly at this time drains and venting. Any good links would be helpful. thank you for your time.
  11. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    You need clean-outs.
Similar Threads: Bathroom Layout
Plumbing Forum, Professional & DIY Advice Wet venting layout for bathroom Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Advice on basement bathroom layout and venting Apr 8, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Remodel Drain Layout and Venting Dec 8, 2015
Plumbing Forum, Professional & DIY Advice Drain layout for adding double sink to existing bathroom Oct 22, 2015
Plumbing Forum, Professional & DIY Advice Back to back bathroom DWV layout Oct 4, 2015
