bathroom and washroom remodel
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brklynfrnt, Dec 8, 2009.
  1. brklynfrnt
    brklynfrnt New Member
    Dec 8, 2009
    North Carolina
    Hi,
    I'm remodeling our bathroom and moving a washer and dryer to the room behind the bath. I've been reading through the posts, which have been very helpful and have a diagram I would love to get some feedback on. I am using some of the existing plumbing which was done a few years ago. I'm adding the washer, moving the WC and adding a utility sink.
    A friend suggested that I connect the washer below the toilet to avoid bubbles. That is the reason for the parallel 3" line. Is that necessary? Also, do I have enough venting?
    Thanks much for your time and feedback!
    [​IMG]
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Are there vents at the lava nd the utility sink? I guess under some conditions you could call what you have a circuit vent but that isn't used too often in residential construction and your vents would be too small for a properly sized circuit.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  5. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Except for wet vents (and circuit vents and comb. drain/vent) which the horizontal becomes the vent....
  6. jimbo
    jimbo Plumber
    Venting the washer with an AAV is a bad idea, because the washer is a pumped discharge...possible positive pressure...and the AAV can't deal with that!
  7. brklynfrnt
    Dec 8, 2009
    North Carolina
    thanks for the feedback
    The utility lav would use an AAV too. Is it possible to attach the washer before the toilet or is it best to attach it after the toilet? I can add non-AAV venting to the washer and the toilet without too much work. How close to the toilet do I need to have the vent? Can it not come out of the main line?
  8. hj
    vents
    for all practical purposes, you do NOT have ANY vents, at least none where they would perform their intended purposes. You have also created a "wasteful" system as far as the cost of installing it is concerned. DON'T listen to friends who do not know what they are talking about. You do not need that 3" line to the washing machine. IF you vent the system properly you will not get "gurgling". IF you do not vent it properly, it will gurgle regardless of where you connect it or what size pipe you use.
Similar Threads: bathroom washroom
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Saturday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Feb 19, 2017
