Bathroom and Kitchen sink Dains slow and girgles
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nthpokt, Oct 14, 2009.
  1. nthpokt
    nthpokt New Member
    Oct 14, 2009
    Utah
    I have a bathroom sink and a kitchen sink that drains really slow and girgles.I've tried several different solutions and cleaners but nothing works for very long.I should mention the the plumbing in this house was new in 1940.Is this the main reason and I have to live with it or is there a good cleaner or home remedy I can use?.......Thanks,Rick
  2. D'Brie
    D'Brie Apprentice Plumber
    Oct 20, 2008
    Apprentice Plumber
    NW Washington State
    You may want to consider having your pipes snaked. Lots of junk can build up over time and (in my opinion) none of the over the shelf "Drain-O" products seem to work, not to mention it's bad for the environment and the person working on your pipes. Call a licensed plumber in your area he/she will be a big help.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    It could be a drain needs to be snaked or possibly the line is so clogged it needs to be replaced...another possibility is a vent is blocked...with 1940s plumbing it should be galvanized drain pipe...I have had to replace those drains many times because the build up was so hard it could not be removed OR once the gunk was removed the bottom of the drain started leaking because it was rusted out....Just FYI...
Similar Threads: Bathroom Kitchen
Plumbing Forum, Professional & DIY Advice Bathroom faucets only trickling water, kitchen is fine Jan 4, 2017
Plumbing Forum, Professional & DIY Advice How to seal bathroom under sink hole &a kitchen marble counter top edges? Nov 18, 2016
Plumbing Forum, Professional & DIY Advice Bathroom face wash faucet drainage and kitchen sink noise Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Kitchen and bathroom reno !!! Feb 25, 2016
Plumbing Forum, Professional & DIY Advice Direct vent bathroom and kitchen sink into main stack? Nov 12, 2015
