Bath tub waste & overflow drain installation.
Discussion in 'Shower & Bathtub Forum & Blog' started by motonutz123, Nov 10, 2010.
  1. motonutz123
    motonutz123 New Member
    Jul 20, 2008
    New York
    I purchased a drain like the one in the link below and it only came with a part diagram. Does anyone know the proper methods and sequence for it's installation? Does anyone know where I can find a set of installation instructions? I also would like to know if the washer at the drain's elbow goes at the top of the tub or at the bottom. I have an old cast iron tub with a 2" drain opening. Thanks in advance.
  2. hj
    IT goes together just like the drawing shows and ALL gaskets go behind or under the tub. NONE go inside the tub. The installation should be so intuitive that I don't know anywhere to find a step by step procedure. Which is also why the only send a parts breakdown. Put the drain in the bottom of the tub, the overflow at the upper opening, and then do whatever is necessary to connect them to the drain tee.
Similar Threads: Bath waste
Shower & Bathtub Forum & Blog Need help picking a bathtub waste overflow (BWO)/drain Jun 17, 2016
Shower & Bathtub Forum & Blog Bath tub waste outlet connection issue - need advice. Dec 29, 2013
Shower & Bathtub Forum & Blog Reliability of cable-driven bath waste? Jul 2, 2012
Shower & Bathtub Forum & Blog What is the best kind of bathtub waste/overflow drain? So confused!!! Nov 8, 2010
Shower & Bathtub Forum & Blog Bathtub drain waste Nov 29, 2007
