I'm replacing a surface mount bath/shower two tap faucet with a delta single lever faucet. Problem is there is a 3" copper drain line in the wall right where the rough in housing should go. There are two apartments below sharing the drain. I can only assume the copper pipe continues up to the roof and vents. Would it be bad aesthetics to mount the rough in off to the side two or three inches? I'm thinking to the right (towards tub outer edge) The Multichoice rough in valve is 2-3/4" deep.
Original Faucet
Behind the wall
Thanks for your input,
Brad
Original Faucet
Behind the wall
Brad
