Bath Overflow drain Gasket issue
Discussion in 'Shower & Bathtub Forum & Blog' started by jestructure, Jan 7, 2013.
  1. jestructure
    jestructure Structural Engineer
    Jan 7, 2013
    Structural Engineer
    New york
    I'm installing a new Americast 5'-0" tub with a Watts brass tub drain assembly.
    everything was moving smoothly until I went to install the tapered washer on the backside of the tub overflow.
    I understand that most of the time the thick side of the washer goes down. In this case, I cannot get a tight seal between the tub and the overflow flange with the supplied tapered washer. IF the bottom is tight, there is a gap at the top. It appears that the angle of the tub and the angle of the overflow flange is nearly identical. I cannot find a thick flat washer locally for this application.
    Any suggestions would be greatly appreciated.
  2. Terry
    Aug 17, 2004
    Turn the tapered washer sidewise. I install them that way all the time in that situation. All you're looking for is a tight seal all the way around. There are tubs that need the taper at the bottom, but certainly not all of them.
Similar Threads: Bath Overflow
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
Shower & Bathtub Forum & Blog Need help picking a bathtub waste overflow (BWO)/drain Jun 17, 2016
Shower & Bathtub Forum & Blog Bathtub replacement - what to do if overflow not centered over drain Dec 2, 2013
Shower & Bathtub Forum & Blog Bath tub drain and overflow Feb 25, 2013
Shower & Bathtub Forum & Blog Wye in bathtub overflow Feb 2, 2013
