Basic wax-ring question
Discussion in 'Toilet Forum discussions' started by brad_j, May 4, 2009.
  1. brad_j
    brad_j New Member
    Apr 25, 2009
    Having been to Home Depot last night, there are a plethora of wax rings:
    - your basic standard wax ring.
    - the oversized wax ring.
    - the reinforced wax ring with some plastic actually in the wax.
    - the waxless wax ring.
    - the extended wax ring.
    The guy at home depot said to get the oversized reinforced wax ring because it is designed for flanges that are installed properly AND for flanges that are a bit low (1/4" to 1").
    Any thoughts?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    On a properly installed closet flange I use a regular wax ring.
    Infact I rarely use anything else, seeing as in the case of an improperly installed closet flange I usually make corrective measures to the flange...
    [​IMG]
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Take all that wax and toss it and get your hands on a 4 lB tub of Sta put plumbers putty.
  5. plumbingskool
    plumbingskool Retired Tradesman
    Feb 25, 2008
    Not Sure ;-)
    NY
    One Answer: Marketing
    As REDWOOD says above, The normal is fine
  6. jadnashua
    Avoid those with the funnel...they tend to cause more problems than they create. If you don't get things perfectly aligned, you can end up with that funnel collapsing and giving you all sorts of grief. If the flange is low, best to raise it or use flange extenders, but a lot of people have success with a thicker ring.
  7. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I can't seem to find the thicker rings without the horn lately.
  8. hj
    horn
    After you use a utility knife on the funnel, NONE of them have a funnel.
  9. Tanker
    Tanker New Member
    May 8, 2009
    NY
    I've been using the one with the funnel for years thinking that it's the better one. What kind of problems does the funnel cause? So after adding a ceramic tile floor just a regular or thick wax ring without the funnel is the best bet?
  10. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    The funnel causes a restriction,use the thick wax or as Mr Ratz said sta put
    putty,used them both and they work fine,but with sta put you have form
    the ring your self.
  11. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I think you must understand that when we say the wax rings with funnels cause problems, it should not be take that every use will create a problem. The real point is, you don't get any benefit from one, but you do get a potential for a problem. We sometimes tend to overstate things.
  12. hj
    rings
    If you read the box, the ones with the fiber "reinforcment" usually state that they are for use with "wall hung" toilets.
  13. Tanker
    Tanker New Member
    May 8, 2009
    NY
    I don't see the thick rings without the funnel in local stores by me, can it be pulled or cut out? Maybe a supply house would carry them.
  14. kingsotall
    Aug 17, 2008
    And I quote,
  15. jadnashua
    Depending on the diameter of the drain pipe and how well you center the toilet on the flange, you could cause the funnel to compress or distort and actually close up. If you install the toilet properly with the wax, and your flange is where it should be, it will last until you decide to replace the toilet.
Similar Threads: Basic wax-ring
Toilet Forum discussions Some basic toilet replacement questions, 10.75" rough May 2, 2010
Toilet Forum discussions Basic toilet from Alcatraz Sep 28, 2005
