basic question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kathy carr, Oct 20, 2005.
  1. kathy carr
    kathy carr New Member
    Oct 18, 2005
    I never thought this could be so complicated. My requirements for a replacement toilet are ADA and a 14" rough in. What are my options??
    Thanks
  2. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    Are you asking what model toilet will work for you? I would expect that any ADA compliant toilet should fit in a 14" rough in. There are many ADA compliant toilets to choose from.
  4. kathy carr
    Oct 18, 2005
    it's the 14 " rough I'm having trouble with
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I believe if you were to change the flange to an adjustable one, you could "lose" 2" and use a regular ADA toilet such as the Toto Drake. Often these flanges are offered as a way to gain 2" from a 10" rough-in to a 12", so I think they should work the other way. If this is not correct, I'm sure I will be corrected.
  6. Terry
    Aug 17, 2004
    The Drake ADA doesn't adjust, it's a standard 12" rough toilet.
    Most 14" toilet combinations are really 12" bowls with thicker tanks.
    As long as there is room, using a standard 12" would be fine.
    If you want to pull the bowl back toward the wall, then there are models that use a Unifit, some are for the 14" rough.
    [​IMG]
    Toto Llyod has a 16.125" bowl height and the 14" unifit can be ordered for it.
    [​IMG]
    Toto Nexus is 16.125" bowl and will work with a unifit.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Thanks for setting me straight. As you could probably tell from my post, I wasn't absolutely sure. It appears that there are easier ways that changing the flange to get around the problem anyway.
  8. hj
    toilet
    Unless the extra space behind the toilet is a problem using a 12" toilet on a 14" rough should not be a problem.
  9. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    eljer tanks
    I believe that Eljer makes a 14 inch rough
    handicapped toilet....the tank is just designed thicker
  10. kathy carr
    Oct 18, 2005
    We've made some compromises and settled on either the Toto Plymouth or the Dartmouth. Any comments on either??
  11. Terry
    Aug 17, 2004
    I like them both.
    Both have good performance and they look really nice.
    I put them in a lot of older Seattle homes, though the new traditional style home would work well with them too.
Similar Threads: basic question
Plumbing Forum, Professional & DIY Advice A few very basic disposal install questions: May 13, 2015
Plumbing Forum, Professional & DIY Advice Basic questions about a kohler shower diverter valve Jan 11, 2014
Plumbing Forum, Professional & DIY Advice Basic question here. leaky clawfoot tub faucet. Apr 6, 2013
Plumbing Forum, Professional & DIY Advice Bathroom sink plumbing question (very basic) Mar 6, 2013
Plumbing Forum, Professional & DIY Advice Sink Shut-offs, Just a couple basic questions, see picture Dec 3, 2009
