basic diy sink drain fitting ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edwardh1, Mar 23, 2014.
  1. edwardh1
    edwardh1 Member
    Jul 21, 2006
    South Carolina
    at the bottom of a kitchen sink, where the sink strainer/tailpiece is , and the water drains out, what sealant if any is used between the fitting and the sink and between the drain pipe and the fitting?
  2. jim mills
    jim mills New Member
    Jan 9, 2014
    nebraska
    No pookey...just a tailpiece washer.
  4. jadnashua
    Underneath the sink strainer when installed into the sink, you use a bead of plumber's putty. Most of it will squeeze out when you tighten things down. Some like to put a little bit on the fine threads that hold the strainer in place, as sometimes, the rubber seal used under the sink for that big nut may not seal well to the threads and you'll get a drip or two down the threads - over time, the rubber may fill in, but those threads are small. But, all of the other fittings are compression fittings (or glue together), and do not need anything else on them.
  5. hj
    quote; Some like to put a little bit on the fine threads that hold the strainer in place, as sometimes, the rubber seal used under the sink for that big nut may not seal well to the threads and you'll get a drip or two down the threads - over time,
    That is a good recipe to ensure that the strainer will have to be cut out when it comes time to replace it. Putty on the threads will do NOTHING to prevent ANY size leak, but WILL "weld" the nut to the strainer.
Similar Threads: basic sink
Plumbing Forum, Professional & DIY Advice Bathroom sink plumbing question (very basic) Mar 6, 2013
Plumbing Forum, Professional & DIY Advice Sink Shut-offs, Just a couple basic questions, see picture Dec 3, 2009
Plumbing Forum, Professional & DIY Advice Installing pedestal sink and basic information Sep 11, 2005
Plumbing Forum, Professional & DIY Advice Basic DWV Sketch Feb 20, 2016
Plumbing Forum, Professional & DIY Advice A few very basic disposal install questions: May 13, 2015
