Basement window wells
Discussion in 'Remodel Forum & Blog' started by andersonwindow, May 16, 2012.
  1. andersonwindow
    andersonwindow New Member
    Feb 9, 2012
    Orem, UT
    If you're thinking about remodeling your house then one aspect you should consider would be safety. After you're done choosing new fabrics and matching colors just stop for a second and think how safe your house realy is?
    Safety is the main reason for installing a basement window well. If there were ever an emergency, the occupants can safely leave the basement, or emergency crews can enter the basement. Here are some examples of basement windows wells:
    -The Mesh cover is built with an expanded metal top. This pattern makes it perfect for keeping out debris, as well as keeping children and pets safe. It can have an unique vinyl coating applied, giving it extra durability agains the elements.
    -The Classic cover is ideal for strength and durability. It’s also a great looking cover and compliments any landscape! It’s built using the InnerFIT system; with a 2†angle iron frame and .5†square tubing, giving it the strength to hold over 750 lbs!
    -The polycarbonate cover is perfect for keeping out debris, rain and snow. As part of the InnerFIT system, the polycarbonate cover can be built with vertical backings to cover windows that rise above the window well.
    So, best thing to do is to install basement window wells on your home today and enjoy the comfort of knowing you’re even more protected.
Similar Threads: Basement window
Remodel Forum & Blog Replacing Basement Windows May 2, 2011
Remodel Forum & Blog Framing inside basement glass block windows Mar 11, 2010
Remodel Forum & Blog Replacing old metal basement windows Apr 5, 2009
Remodel Forum & Blog Basement Double Vanity + Laundry Jan 23, 2017
Remodel Forum & Blog Identifying issues with installing freestanding tub in basement Jul 11, 2016
