Basement Washing Machine Drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ScottTENN, Nov 20, 2008.
  1. ScottTENN
    ScottTENN New Member
    Apr 28, 2007
    What line is safe for a washing machine to drain into? In my basement remodel my wife and I talked about possibly moving the laudry to the basement. I thought if nothing else I could at least get the power and water setup for us or the next guy.
    I have a 3/4 bath in the basement already right beside what will be the unfinished furnace/laundry room. So supply and drain are close. The basement bath has its own vent (1 1/2"?), though I assume it gets connected back to a main vent in the attic.
    Can I just waste into the shower vent for my washing machine?
    [​IMG]
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'll leave the evaluation of the entire plan to the pros, but I can tell you that your washer must have a 2" trapped and vent drain. I think you could share the vent as a vent but not as a waste.
  4. Terry
    Aug 17, 2004
    You can not waste over into the shower vent for the washing machine drain.
    The washer would siphon the trap of the shower dry in seconds.
    The santee on it's side for the shower needs to be replaced with a wye.
    The vent needs to have a wye fitting also.
    If you want to add a washer, add another wye before the shower vent, and come up alongside of it.
    Add a santee on the vertical about 12" above the floor, and use a 2" p-trap with a 30" standpipe.
    The two 1.5" vents can then tie together at 6" above the standpipe for the washer.
Similar Threads: Basement Washing
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Washing machine and Laundry Tub basement remodel Jan 11, 2015
Plumbing Forum, Professional & DIY Advice Drain washing machine on first floor to laundry tub in basement? Jul 29, 2013
Plumbing Forum, Professional & DIY Advice Washing Machine Drain in Basement w/ CAD Drawing Mar 28, 2013
Plumbing Forum, Professional & DIY Advice recommend best way to pipe sink/washing machine in basement Feb 22, 2013
