Basement shower trap rough in height
Discussion in 'Shower & Bathtub Forum & Blog' started by Rich_B, May 21, 2008.
  1. Rich_B
    Rich_B New Member
    Mar 6, 2006
    After I remove some concrete to set the p trap for a shower pan, what's a good rough in height for the trap? An inch or two below the bottom of the concrete slab then cut the excess 2" pipe before installing the pan?
    Does it depend on make/mfgr of the drain or are all shower drains standard?
  2. jadnashua
    It really depends on the pan and the drain assembly you are going to use. I think you'll want the trap deeper than that IF your drain line will support it for some flexibility. If it is that close to the surface, I think you'll really restrict your choices.
    If you are going to be tiling things, check out www.johnbridge.com.
Similar Threads: Basement shower
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog prestubbed shower drain in basement May 16, 2016
Shower & Bathtub Forum & Blog Basement Floor Drain as Shower Drain? Mar 9, 2016
Shower & Bathtub Forum & Blog basement shower drain / floor drain Jan 1, 2016
Shower & Bathtub Forum & Blog Building a basement shower from scratch Oct 24, 2014
