Basement Shower Install
Discussion in 'Shower & Bathtub Forum & Blog' started by dennis51, Apr 12, 2011.
  1. dennis51
    dennis51 New Member
    Apr 12, 2011
    South Saint Paul Minnesota
    Hello,
    I am putting in a bathroom in my basement. On the cold wall I put 2 inch pink styrofoam insulation from corning and I then framed a wall over that. the shower is going in the corner where one wall will be next to the pink stuff and the other wall will be against a dry/warm wall. Is the pink stuff good for a vapor barrier against the cold wall, and do I need to put a vapor barrier where the warm wall is? I am going to use Durock Cement Board for the walls.
    I appreciate any suggestions
    Dennis
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The "pink stuff" is extruded foam, and acts as a vapor retarder. Because of it's fire and smoke spread characteristics, it must be covered with a 15 minute thermal barrier when used indoors. Drywall is the only approved barrier I am aware of, though there might be others.
  4. Shower Pod
    Shower must be fitted to the cold side of the tap and you must use a small and handy shower which can be easily fitted and don't create any problem to get fitted and it will fit in small space also.
    __________
    shower pod
Similar Threads: Basement Shower
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog prestubbed shower drain in basement May 16, 2016
Shower & Bathtub Forum & Blog Basement Floor Drain as Shower Drain? Mar 9, 2016
Shower & Bathtub Forum & Blog basement shower drain / floor drain Jan 1, 2016
Shower & Bathtub Forum & Blog Building a basement shower from scratch Oct 24, 2014
