Basement rough plumb - what's this?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by prashster, Sep 19, 2006.
  1. prashster
    prashster New Member
    Dec 7, 2005
    A guy on JB's forum had this pic of his basement bath rough in. Anyone know what the yellow arrow's pointing to?
  2. hj
    thing
    It is the "blockout" box for the tub or shower "P" trap.
  4. prashster
    Dec 7, 2005
    Thanks, HJ. Knew you'd be here ;)
    Why is that required? Why can't you just cement the ptrap in like everything else?
  5. jimbo
    jimbo Plumber
    San Diego, CA
    At the slab-pour stage, you have no way to accurately detemine the exact final placement of the trap....your rough sill plates and walls are not even set at that time. The final location of the trap can be set inside this box once your rough framing is up.
  6. prashster
    Dec 7, 2005
    Thanks Jimbo!
  7. v1rtu0s1ty
    v1rtu0s1ty DIY Senior Member
    Sep 18, 2006
    Chicago IL
    Thanks phrashter for posting the pic here. Am now a member of terrylove too. :D
    By the way, I'm a visual type of person. What is a P trap?
  8. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    I did a google image search and saw those P-traps :D
    From what I'm currently seeing in my basement, I have to make a big square cut on that black plastic. Am I correct?
  9. hj
    thing
    First you have to understand that most of the lower portion of a tub drain is below the floor so that big box gives you room for it. It also may give you room to cut the trap off and repipe a new trap if it has to move to a different, nearby, location to line up with the bathtub.
Similar Threads: Basement rough
Plumbing Forum, Professional & DIY Advice Help with my basement drain rough in layout Apr 6, 2017
Plumbing Forum, Professional & DIY Advice Sorting out basement rough-in Apr 3, 2017
Plumbing Forum, Professional & DIY Advice Basement Rough in Confusion Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Basement Rough plumbing Dec 13, 2016
Plumbing Forum, Professional & DIY Advice Basement Rough-in Stubs Jul 31, 2016
