Alright, I thought I had everything figured out, and then BAM -- It was mentioned to me that if the 2" pipe is was meant to be a sink when plumbed then no p trap.. which means no shower/tub.. without of course slab breakup and below grade plumbing work..... Which I had wanted to avoid.
So here is the floorplan with measurements of the rough in location. Please can someone shed some light on how these pipe locations are meant to be used. I am also in the process of seeing if the builder knows if there is a p trap for a shower on the 2" pipe, or maybe the city permit office knows... I read that I could pour water into the 2" drain and see if it all drains away (no p trap), or if I can see it down the pipe (a P trap).. but I didn't want to cut the pipe open until I am ready to proceed.
My big dilemna is if this is meant to only be a toilet and sink, then this rough in layout makes no sense to me.... If it is meant to be a shower/toilet.. then they did a poor job of spacing as I can't find a shower pan that would fit well in the space that is left. If it is supposed to be a tub.. then there is no "dap-out" and again location makes no sense....
So here is the floor layout, with measurements.. measurements are to the center of the pipes. The wall layouts are what I have been planning.. the dark gray thick wall is foundation wall. The dark gray thin wall can move left but not right. The "wall" where the vent stacks go up seems a no brainer. The toilet rough in is 1'6" from the center of the vent pipes to the center of the toilet rough in. The 2" pipe is 3' 9 1/2" from the vent pipe "wall". The toilet rough in is 4'9" from the foundation wall, and the 2" pipe is 1' 10 1/2" from the foundation wall.
The shaded region is a reduced ceiling height of 6'11" due to vent obstructions, so it can be ignored for this discussion. All the light gray walls can be moved, they are just what made most sense to me. Here is the diagram....
So again my main question here is what layout is this rough in designed for? IE what did the plumber/builder have in mind for bathroom layout that had them put the pipes where they are.
Thanks
Thanks
