Basement rough in - does this look OK?
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by export!, Jul 18, 2011.
  1. export!
    export! DIY Member
    90
    Ontario, Canada
    I'm hoping to keep this simple and I think the drawing has all the info. The 2" shower vent will continue out the roof and the 1-1/2" vents from the lav and laundry will tie together 5' up, and pick up the 2" above the ceiling. I couldn't find a long turn 90 for the closet bend fitting in the drawing but I will either use one or use two 45s.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    3,135
    Maine
    It would fly under the IPC but many localaties still require a vent for the toilet line
  3. hj
    26,515
    I would forget the "long turn 90, or two 45s" and use a hub 4x3 closet bend. It is the ONLY way I install my toilet riser pipes.
  4. export!
    export! DIY Member
    90
    Ontario, Canada
    Interesting
    Thanks very much for the input. I guess I'll have to run it by the inspector. I'm located in Ontario and I'm not sure what our code is. I guess it's close enough to not get laughed or yelled at!
    That 4x3 fitting is cool - I've never seen one of those before. I can see how well they would work but is that the only time in DWV plumbing you're allowed to in effect reduce the pipe size ??
    If I need to vent the closet, I would change the shower vent to 1-1/2 and vent the closet with 2" correct? At that point could I connect the other vents from the group and run to the roof with 2" ?
  5. Tom Sawyer
    3,135
    Maine
  6. Jerome2877
    Jerome2877 In the Trades
    397
    BC
    You are fine under the Canadian national code, the toilet is wet vented and is 2".
  7. export!
    export! DIY Member
    90
    Ontario, Canada
    Jerome - thank you very much - the inspector agrees! Good to go. He mentioned something about 5' being good. I imagine it's that the shower drain/wet vent connects to the 3" horizontal run within 5' of the toilet flange.
    Edit - from planning to completion!
      File size:
      79.6 KB
      491
Similar Threads: Basement rough
Plumbing Forum, Professional & DIY Advice, Tips & Basement Bath rough-in with Diagram Jul 14, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Basement Rough in Plumbing Identification and Solution Apr 29, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Basement rough in help Apr 23, 2014
Plumbing Forum, Professional & DIY Advice, Tips & basement bath roughed in wrong? Apr 13, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Basement Shower Drain Rough under (Black Box) Feb 25, 2014
