Basement remodel.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mateo Matrona, May 16, 2014.
  1. Mateo Matrona
    Mateo Matrona New Member
    May 16, 2014
    Illinois
    Need advice on tools needed to cut pipe and also thread for standard sink shutoff valve. Posting pictures in a moment. Thanks.
  2. Mateo Matrona
    May 16, 2014
    Illinois
  4. Mateo Matrona
    May 16, 2014
    Illinois
    If you need any other information please ask.
  5. Terry
    Aug 17, 2004
    That's a standard 1/2" galavanized pipe. You can thread on a shutoff, or you can rent a threader and cutter. If you cut and thread, you will need cutter oil too.
    Or you might take it back to the next fitting and use a male thread from there.
  6. Mateo Matrona
    May 16, 2014
    Illinois
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    .......... fat fingers
  8. Terry
    Aug 17, 2004
    Not the compresson style. You would want the IP version. (iron pipe)
    You could just unthread those ends and thread on a shutoff now.
  9. Mateo Matrona
    May 16, 2014
    Illinois
    I tried everything and those ends wont budge. Any ideas? PB Blaster?? Heat gun??? I have done alot with PVC but not galavanized pipe.
  10. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You have to use pipe wrenches that are big enough to get some leverage. It's a matter of leverage and muscle, along with a little good technique.
  11. Terry
    Aug 17, 2004
    A little heat from a torch will expand the brass and allow for easier removal.
  12. Mateo Matrona
    May 16, 2014
    Illinois
    Thanks everyone for the advice. One last question tho. I will be turning left on those ends and right on the upper pipe correct? Thanks in advice. I will be doing this tomorrow evening.
  13. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    That would depend on which way you are looking at it. Pipe thread turns the same direction as common bolts and nuts.
Similar Threads: Basement remodel
Plumbing Forum, Professional & DIY Advice Guidance for basement remodel Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Washing machine and Laundry Tub basement remodel Jan 11, 2015
Plumbing Forum, Professional & DIY Advice [3D diagram] Basement Remodel Bathroom Help (add shower) Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Please review the piping plan for basement remodel Jun 21, 2013
Plumbing Forum, Professional & DIY Advice Basement remodel - bathroom DWV review? Jan 3, 2013
