Basement insullation vs wiring
Discussion in 'HVAC Heating & Cooling' started by richrc1131, Sep 21, 2009.
  1. richrc1131
    richrc1131 New Member
    Apr 16, 2008
    Central Connecticut
    I hope this is the appropriate place for this question. Here it goes:
    I need to insulate my basement, but there is a lot of wiring between the support joists. I can get the insulation behind all of that, but I wanted to know what are the general code considerations in this situation.
    Do I have to do anything special at junction boxes or anything like that?
  2. Ian Gills
    Jul 24, 2007
    USA
    A few things to consider and I am sure others will add more.
    First, you need to be careful when covering light fixtures with insulation. The lights needs to be rated for this purpose.
    Second, junction boxes need to be accessible. They cannot be hidden behind drywall. This may require the use of a) access panels or b) a suspended ceiling.
  4. richrc1131
    Apr 16, 2008
    Central Connecticut
    Possible silly question here: Is it safe to leave fiberglass roll insulation uncovered? Meaning, since I have to insulate the basement ceiling and I also have to install a drop ceiling, do I run any health risks by leaving the drop ceiling portion of this project for a later time?
  5. Ian Gills
    Jul 24, 2007
    USA
    If it's got the paper backing on it, then technically this should not be left uncovered since it might present a fire risk.
  6. richrc1131
    Apr 16, 2008
    Central Connecticut
    No health worries though?
  7. jadnashua
    Fiberglass insullation can shead fibers, so it would be a good idea to try to prevent that. Any air movement across it can result in a shower of fibers as can contact, which are not the greatest thing to inhale or to get on you. So, maybe staple up some plastic or paper. It should be fairly easy to remove, if desired, when you get to install the ceiling and won't take much time or money to install. Both faced and unfaced fiberglass will burn.
  8. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
Similar Threads: Basement insullation
HVAC Heating & Cooling Guidance needed on designing basement HVAC Oct 17, 2015
HVAC Heating & Cooling Hot water baseboard heater in basement - install Oct 11, 2015
HVAC Heating & Cooling DIY Basement ventilation and boiler Feb 20, 2015
HVAC Heating & Cooling Heating Basement & Up satires Should you separate heating systems Sep 1, 2014
HVAC Heating & Cooling Chilly Finished Basement Needs Cold Return? Mar 26, 2014
