Basement floor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by idoc4u, Nov 19, 2009.
  1. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    Does anyone have a recommendation regarding the type and number of bag mix of concrete best used to fill and finish a basement floor after having cut the original concrete floor to relocate DWV PVC?
    Thank you.
  2. hj
    concrete
    Bags of "pre mixed" concrete. Use a many as necessary for the hole size.
  4. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    Thanks hj!
    hj,
    Thanks for the recommendation.
    I was overthinking, I guess.........idoc
  5. jadnashua
    It's best if you drill some holes and insert some rebar to anchor the new and old concrete together. A couple of stubs on each side of the hole and maybe more, depending on the size of the hole is a good idea to tie the old to the new.
  6. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Measure the volume of concrete you'll need and buy the # of bags needs to fill that much volume.
    L*W*H
  7. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    thanks again
    Thanks again, guys....idoc
Similar Threads: Basement floor
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Check valve needed? Water on floor of basement. Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Emergency Floor Drain In Basement May 3, 2016
Plumbing Forum, Professional & DIY Advice HELP! Mystery under basement floor... Aug 4, 2015
