Basement DWV Mock up Photo
Mista T
Above is a mock up to correct some issues with my previous waste line install posted last night. I put this mock up together based on Forum feedback. Does this appear to be a correct solution? Also, is there a min/max span between the Wye/45* combo & P trap outlet? All are 2" pipe. I know the standpipe for clothes washer on the right side is to be a min of 18". AAV will be mounted on the left riser pipe.
Many thanks again.
Tom
Tom Sawyer
Maine
Nope, that wye and 1/8th bend should be a sanitary tee. And you can't use the rubber, un-shielded coupling inside.
