basement drain question for adding wall hung toilet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bull, Dec 9, 2011.
  1. Bull
    Bull New Member
    Dec 9, 2011
    Concord, N.C.
    Really would like to install a wall mounted toilet (geberit style) and small sink, My question is this.....My sewer drain line runs about 32" above the floor, now where I want this bathroom is in an area where the drain pipe runs vertically up and down. Water supply is here also, Can I tap into the main down pipe with a Wye to connect the toilet, the reason for the wall mounted toilet is to give me height compared to a floor mounted one, also I would need to vent this but don't see the vent line, any thoughts, thanks in advance. .............Dan
    [​IMG]
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    How are you going to use a toilet 32" of the floor? Very carefully I bet.
    John
  4. Bull
    Bull New Member
    Dec 9, 2011
    Concord, N.C.
    Thanks John for your time, I was referring to where the pipe leaves my home, it is on a vertical run at this point, and drops below the floor, by using a wall mounted toilet the drain is higher on that than a traditional floor mounted toilet, can I simply tap into that pipe with a wye and hook it to the wall mounted toilet drain, any ideas on venting?................Thanks Dan
  5. Terry
    Aug 17, 2004
    You would vent the toilet before it entered the main stack. 72" is the max distance.
    The same would be true for the lav. The lav would need to be vented within 42" before it can wye in somewhere else.
  6. hj
    quote; I was referring to where the pipe leaves my home, it is on a vertical run at this point, and drops below the floor,
    That is even more confusing. IF the pipe "leaves my home" is 32" above the floor, how will you connect a toilet to it? But, if there is a "vertical run that drops below the floor", then why even mention the 32" high pipe? You CAN "simply insert a tee" for the toilet, but that is usually the EASY part. Between the tee and the toilet, you DO need a vent, and if you add a sink, the piping becomes more complicated. There is no existing "vent line" because the piping you now have does NOT need one in the basement. You have to install it, which is why I said "installing the tee is the easy part of the job".
Similar Threads: basement drain
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
Plumbing Forum, Professional & DIY Advice 4" Storm Drain into Basement... Oct 9, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Help with basement drain Sep 15, 2016
