basement bathroom on slab
Discussion in 'Remodel Forum & Blog' started by richd, Nov 13, 2005.
  1. richd
    richd New Member
    Nov 13, 2005
    I am going to install a 3/4 bath in my basement and the plumbing is already stubbed out. I was wondering if it is recommended that I install the fixtures directly on the concrete or build up a subfloor. Also, do I need to place the shower stall directly over the drain pipe or is there enough room under a shower stall floor to move it to the side some?
  2. jeffreyhel
    jeffreyhel New Member
    Nov 4, 2005
    Setting the shower pan directly on the concrete floor is fine. Follow the manufacturers directions for what to set it on or in. NO, there is no room under the pan to offset it unless the verticle pipe in the ground can be offset with fittings. I would suggest some sort of tile,linoleum or vinyl finished floor so it can be cleaned properly.
  4. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    old bridge nj
    set the pan in mud directly on slab. drain and pipe connection has to be dead on. no play there. i usually pour a floor leveler after pan is set. basement floors are never level.
  5. alhurley
    alhurley Guest
    ya gotta check out da John Bridge forums if you're doin' a shower. :)
Similar Threads: basement bathroom
Remodel Forum & Blog Roughing in Bathroom in Basement Early 1900s vintage house Feb 28, 2013
Remodel Forum & Blog pipe length for basement bathroom fan Feb 4, 2013
Remodel Forum & Blog prepare for the tile basement bathroom Dec 1, 2012
Remodel Forum & Blog add subfloor in basement bathroom May 4, 2012
Remodel Forum & Blog basement bathroom and utility room floor insulation Dec 24, 2011
