Basement bathroom floor broke up. Does this layout work?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GTJackets, Jan 29, 2014.
  1. GTJackets
    GTJackets New Member
    Dec 4, 2013
    TN
    Is this a proper way to plumb a basement bathroom?
    1. lav drain
    2. shower
    3. toilet
    4. vent for toilet
    5. is hard to see but is a 2" Wye rolled above the horizontal to vent the shower.
    Question:
    Is the toilet vented by the vent for the shower(#4 in the photo)?
    Or is the toilet wet-vented by the lav drain(#1 in the photo)
  2. Terry
    Aug 17, 2004
    The biggest concern if venting between the shower and the toilet.
    The shower vent will also vent the toilet, but normally you like to see the vent come off at a 45 or vertical and not flat.
    You may want to at least roll it to keep it above the flow line of the shower waste line.
    If you have other bathrooms coming down that line, then the lav woudn't really be venting the toilet.
    I vent before a fixture enters a waste line.
  4. GTJackets
    Dec 4, 2013
    TN
    This is not my setup but I am in planning stages and looking at other's rough in
    Good point on venting before a fixture enters a waste line.
    Thanks
  5. GTJackets
    Dec 4, 2013
    TN
    As a clarification, fitting #5 is a 2" Wye and will be rolled above the horizontal to vent the shower. Like the drawing below.
  6. yngwie_69
    yngwie_69 New Member
    Sep 8, 2009
    Prince Rupert, BC
    though lav sink was the only thing u could wetvent a toilet with. wouldnt a double wye be better and vent toilet of the left side and tie into the shower vent
  7. GTJackets
    Dec 4, 2013
    TN
    Not true but the lav is the most common
  8. hj
    quote; Good point on venting before a fixture enters a waste line.
    If the vent is after the fixture enters a waste line the vent will be decorative, i.e., it will look pretty but won't serve any actual purpose.
Similar Threads: Basement bathroom
Plumbing Forum, Professional & DIY Advice New basement bathroom Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Basement Bathroom Plumbing Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Help with basement bathroom plumbing design Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
