I would like to install a basement bar in an unfinished room in my basement. The bar will be on an exterior wall. There are 2x4 furring strip walls with fiberglass insulation against the 8" foundation walls. The main stack is about 32' feet away on the exterior wall. Can I run the drain plumbing through 2x4 furring strips, in front of fiberglass insulation? What size of drain pipe should I run to the main drain stack? Can I get by with 1.5"?
