Basement - Air movement
Discussion in 'HVAC Heating & Cooling' started by ScottTENN, Oct 23, 2008.
  1. ScottTENN
    ScottTENN New Member
    Apr 28, 2007
    First I would like to say thanks to the site. I got some great advice on how to add a shower to the 1/2 bath rough-in making it a 3/4 bath now!
    More work in the basement....
    I have been working on finishing my basement and plan on drywalling the ceiling. I just don't have the height clearance for a drop ceiling and I just dont really like the way they look. Because the ceiling is a bit low, somewhere around 7 feet finished, I want some type of air circulation; A ceiling fan. But I dont want my head smacked all the time.
    My solution is this. Within the walls I would like to put a register towards that top of a wall and one towards the bottom and put some type of blower between the two. Give it a reversible switch to blow from the top or the bottom. Say one of these on each wall, maybe one master switch, variable speed?? Maybe even have the registers in the ceiling pointing down and the other still near the floor to simulate a ceiling fan.
    I only have two registers in the basement that are attached to the HVAC. One on either end of the basement. I just need a way to move some of the air around that is already down there.
    Has this been done? Can it? Worth it?
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
  4. tedfrk
    tedfrk New Member
    Oct 21, 2008
    New Jersey
    if the basement is going to be finished put in a small return down there in the middle of the room if possible.
  5. ScottTENN
    Apr 28, 2007
    The Grainger idea is much closer to what I want, but that will be difficult to get in between and behind a 2x4 wall without a big hammer. We have some Grainger catalogs here at work, I'll have to go though them. They may have something. I do have a soffet that runs the length of the basement, to cover the "I" bream. There is room to mount such a device. It just wont go exactly were I want it.
    As far as adding another return, I can still do that. I may need to anyway. I don't have a return in the basement, unless it is right off the furnace. I will have to look. I'm looking to provide a forced air solution. I happen to like a slight breeze in a room, the wife... not so much. But guess's my basement.
    Ideally I was looking for a something that would suck and blow. Just like a ceiling fan you can flip the switch and it will either suck air up or blow air down. I wanted the same effect with just the fan in the wall. Suck air from the bottom of the room and blow it out the top and vise vera.
    Too many ideas, too little money.
    Thanks for the ideas!
Similar Threads: Basement movement
HVAC Heating & Cooling Basement Bathroom HVAC Question Apr 17, 2016
HVAC Heating & Cooling Basement heating duct help Mar 6, 2016
HVAC Heating & Cooling Guidance needed on designing basement HVAC Oct 17, 2015
HVAC Heating & Cooling Hot water baseboard heater in basement - install Oct 11, 2015
HVAC Heating & Cooling DIY Basement ventilation and boiler Feb 20, 2015
