BaseBoard heating Slant/Fins
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jaysn, Nov 17, 2008.
  1. jaysn
    jaysn New Member
    Nov 17, 2008
    Bought a House several years ago... and the base board heating, runs around the perimeter of the first level... but about HALF of the piping doesnt have any fins installed.... Obviously, the pipes still heat, but not as effectively... Is there a "Snap-on" "Bolt-on" FIN product i can buy, and install in sections... or does the entire piping need to be replaced for more efficient heating. Thanks
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The length of the finned sections should be calculated to match the heating needs of the room.
    The boiler is also sized for the needs of the house.
    This is not something that you just blindly add to! I would consult a heating pro.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It's probably dummy base that is just there to conceal the pipes. If the house heats ok leave it alone.
Similar Threads: BaseBoard heating
Plumbing Forum, Professional & DIY Advice put ball valve(s) on each water heating baseboard branch? Oct 2, 2014
Plumbing Forum, Professional & DIY Advice slow leak on CI baseboard (water heating) air pressure testing Sep 23, 2014
Plumbing Forum, Professional & DIY Advice Threaded brass fittings ok in baseboard heating system? Jun 7, 2013
Plumbing Forum, Professional & DIY Advice Adding baseboard heating to my current system. Nov 12, 2012
Plumbing Forum, Professional & DIY Advice Installing Baseboard Heating Jun 9, 2008
