Baseboard heater valve replacement
Discussion in 'Boiler Forum' started by Mikeiii, Jan 27, 2009.
  1. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Hi
    I have a baseboard heater valve with a broken stem. The nut to remove the stem is frozen. My plumber was unable to loosen the nut holding the stem in place and didn't want to remove the valve because he was not sure he could find a replacement. ( The system is 55 years old).
    Does anyone know where I can get a replacement or if I remove it if I can get it rebuilt?
    Attached is a photo of the valve.
    Thanks
    Mike
    (sorry for the duplicate posting I posted this on the electrical forum first and couldn't figure out how to move it)
  2. msgale
    msgale Member
    Sep 28, 2006
    depends more on the pipe feeding the valve, than the valve itself.
    Assume the valve isnt salvageable.
    the photo isnt clear enough as to what type of pipe do you have off to the right of the valve, between the valve and radiator?
    if it's copper, which is what it looks like, you just remove valve, unsolder or cut pip, and re do the whole angle valve part w same size of copper pipe and a new valve that will fit in.
    and yes, you will need to drain the system to do this.
    Or, if the valve is ok as is, just ignore the whole problem.
  4. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Basebaoard Heater Valve
    Thanks for the reply. All the pipes are 1" copper.
    I was hoping to be able to just replace the valve but the union on the value I found at Grangier was the wrong size and it had a threaded pipe off the union.
    Do they make a valve with a 1" copper pipe coming off the union? I can make the one I found work but I will not be able to put the cover back on the radiator.
    By the way disregard the 1 and 8/5" shown on the photo it was a typo.
    Mike
  5. msgale
    msgale Member
    Sep 28, 2006
    why not just cut or desolder off the valve and ells, and re pipe the whole visible area w a one inch copper pipe and a vlave that fits the space?
    you really dont need the union: when was the last time you opened the union to remove the radiator?
    and, no union makes it easier to get a valve that will fit
  6. Mikeiii
    Mikeiii New Member
    Jan 27, 2009
    California
    Radiator Valve
    Thats a great suggestion! I'm not a plumber but I've had a couple look at this and they focused on a valve with a Union. The building is 50 years old and I don't think the Union has ever been used.
    Thanks for the idea.
    Mike
Similar Threads: Baseboard heater
Boiler Forum BaseBoard to Runtal Wall Radiator retrofit Feb 11, 2017
Boiler Forum How calc BTU of a baseboard section Dec 17, 2016
Boiler Forum Extending a baseboard radiator - Need the return to stay above the floor Nov 30, 2016
Boiler Forum Replacing hot water baseboards with PEX Feb 1, 2016
Boiler Forum Noisy baseboards...air in system? Nov 29, 2015
