Baseboard Heater Clearance
Discussion in 'Toilet Forum discussions' started by ohtara1211, Jun 1, 2005.
  1. ohtara1211
    ohtara1211 New Member
    Jun 1, 2005
    I just tried to install a Toto Drake ADA toilet on a twelve inch rough. To my surprise it would not fit because the base will not clear the baseboard heater in back of the toilet like the original did. My contractor said I needed to buy a "high clearance toilet', but my local plumbing store looked at me like I had two heads. I guess I could go to a ten inch rough, but that would push the toilet out 2 more inches.
    Does anyone make an ADA toilet where the base does not go as far as the back of the tank?? Thanks, Jeff
  2. hj
    Probably a lot of companies do, but you would have to check at a showroom since we do not know how high and deep your baseboard is.
  4. Terry
    Aug 17, 2004
    A heater behind the toilet?
    You might try the Gerber 21-318
    or Toto Dalton CST734F
  5. jdkimes
    jdkimes Engineer
    Littleton, CO
    Melting wax ring.
    I was wondering if a heater or any other heat source that is very close to the toilet and/or flange might have a very good possibility of melting or at least severely softening the wax ring.
    Is that possible? Does that happen?
    Just a thought. Thankfully I don't have any heaters near a toilet (seems like a sanitary problem too- splashing, bad-aim etc)
Similar Threads: Baseboard Heater
Toilet Forum discussions Toilet suggestions for 11" rough and baseboard heater behind. Jul 28, 2015
Toilet Forum discussions Tuff Rough In for toilet with baseboard heater behind Apr 4, 2012
Toilet Forum discussions TOTO fit problem w/ baseboard heater behind Sep 17, 2010
Toilet Forum discussions Toilet needed that will clear hotwater baseboard heater Nov 14, 2009
Toilet Forum discussions Fitting Toto to 13 7/16 rough-in to wall, but less with baseboard and shoe molding Jul 30, 2014
