JohnfrWhipple
BATHROOM DESIGN & BUILD
Over the years my design style for curbless showers keeps changing. This is because with every new job I get better, I learn more and have studied more. With each passing month I have helped more people and learned of more hurdles to over come. Basic principles start forming. These get refined and then I make up rules of sorts. Not TTMAC rules. Not TCNA rules. My rules. And the first one is a big one.
One of my golden rules is that a shower should always be able to hold 1" of water above the shower grate before things go horribly wrong. There are many reasons for this but the primary reason is that it takes on occasion a little head water build up above a drain before a drain starts meeting it's max flow rate.
Some drains work fine with 3 gallons of water per minute. Same drain with 12 gallons per minute might see a head water build up of 3/8". Add a hand sprayer to the mix and change to flow pattern on the floor and then you might see 5/8". These are tough lessons to learn in the field. When you learn them - it's costing you money to fix.
So - I follow my rules and one of the big ones like I said is the 1" rule.
In the photo below you can see my nasty 4' level.
It's sitting on the ACO shower drain with a stack of tile. The tile is 3/8" thick. Plus a 1/8" red shim. So I have just over an inch. The level reads level in this photo so I can measure the grade change.
To gain this measurement I need the help of my capillary break (shown to the right). A capillary break is another rule and one I can cover later.
RULE #1
Have at least 1" of water build up in the shower before the
"OH Shit Point!"
"OH Shit Point!"
