Banging noise from toilet after flushing
Discussion in 'Toilet Forum discussions' started by thatgirl2478, Mar 8, 2007.
  1. thatgirl2478
    thatgirl2478 New Member
    Jul 1, 2006
    Illinois
    We're in the process of adding a second bath to the basement. We had the concrete broken and the soil pipe tapped into to run a new line to where the new bath will be. This was all done by a pro.
    Shortly after this job was finished (note that we have all the connections 'capped' off in the basement until we can finish the rest of the bathroom - so no fixtures yet) we noticed that after flushing the toilet on the second floor (existing) we would hear a bang or thud coming from we think the floor area (or somewhere below us).
    Any one have any idea what it could be?
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Have someone flush while standing by the stack in the basement..
    See if you can locate the exact source of the sound...
    Might be so simple as to be a loose pipe....
  4. BeauSoleil
    BeauSoleil New Member
    Mar 7, 2007
    Sounds like a water hammer to me
    When the new plumbing was stubbed (connected) into the existing house water supply, being that the new work was in the lowest part of the house, it necessitated draining at least part of the system. My guess is that prior to the work, some location in the system had a column of trapped air which absorbed the shocks associated with water flow (as in a toilet filling) when it was suddenly shut off, as happens when the toilet tank reaches full, especially with Fluidmaster sudden off type Fill valves.
    If my guess is correct, having a water hammer preventer added to the system should cure the problem.
    Not an Expert.
Similar Threads: Banging noise
Toilet Forum discussions banging pipe to toilet Feb 12, 2007
Toilet Forum discussions banging sound Sep 2, 2006
Toilet Forum discussions Loud Jackhammer Noise When Toilet Flushed In Morning Feb 14, 2017
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
