Ball valves with drains
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jf, Aug 12, 2005.
  1. jf
    jf New Member
    Jun 5, 2005
    I am replumbing a bathroom and was wondering if the small drains on the valves are bad about leaking or would it be better to use the ones without drains.
    Thanks in advance
  2. plumguy
    plumguy New Member
    Jul 15, 2005
    Personally, I think the drains are waste of money, I have never seen a use for them including silcocks that are maintenance free!!!
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The only use these valves have are when you must drain a line to prevent freezing, and then only if the valve is at the lowest point in the line. Save yourself grief and use regular valves.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    I've never seen a down side to using stop and waste valves.
    And they can be usefull if you have to dry out a line for sweating and not have to shut the whole building off.
Similar Threads: Ball valves
Plumbing Forum, Professional & DIY Advice Welding PVC ball valves Jun 15, 2016
Plumbing Forum, Professional & DIY Advice PEX ball valves - Lead vs. Lead Free Mar 31, 2015
Plumbing Forum, Professional & DIY Advice Can all brass full port ball valves be used for hot water? Sep 20, 2012
Plumbing Forum, Professional & DIY Advice Red & White 1/4 Turn Ball Valves STILL OK to use? Jan 30, 2012
Plumbing Forum, Professional & DIY Advice Ball Valves - Forged Brass vs Forged Bronze Jun 11, 2011
