Ball valves - are they created equal?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lurch, Jun 17, 2009.
  1. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    I need to replace my 3/4" main shutoff ball valve as
    1. the handle is rusting through
    2. on a recent pipe replacement job there was a small amount of leakage (maybe this is normal)
    3. I want to upgrade my main supply through the house to 3/4" - and I'm not sure if trying to attach a 3/4" male fitting to this valve will work.
    I have 2 in my possession - a chinese Matco and an Italian Mueller - both sweat. My plumber swears by Watts and as this is a pretty important valve - I'd very much appreciated the learned opinions on this forum as to what they would install.
    Also - my current valve is a compression - I would like to replace with a sweat fitting - is this advisable? I'm in NJ and I'm assuming the main pipe inlet is thicker copper.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    That's a compression valve. Wow. Showing my greeness. Never seen a valve like that.
    Your plumber seems to be spot on with his choice. Trust the man.
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    That is an IPS valve.
  5. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    yep - its not a compression - just a threaded valve.
    Seems I have 2 choices - try to remove the threaded reducer fitting at the top to replace with a 3/4 straight male
    or
    get the water shut -off and replace the whole valve
    any suggestions?
  6. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    wouldn't any solution be just as easy?
    Shutting off the ball valve, cutting the copper, unscrewing fitting from the valve, screwing in new copper mip adapter and pipe?
    Shutting off city line/meter, cutting copper, sweating on new ball valve, sweating on new 3/4" tubing?
    of the valves you have, I'd use the Mueller.
  7. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    The valve still works? Does it leak? If it works and is not leaking why not jsut change the handle and nut? If you can not find a new handle just take the old one off can clean it up and hit it up with some rustoleum.
  8. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    Thanks for your reply Brent - your probably right - its just in my town they want $60 to shut off the water at the street - the access point is visible (and brand new - as they had to replace and test it last fall)
    Not only is it the money - its syncing up with the water guys to get them out on a weekday at the right time.
    If I could turn it off myself.... - I would go for the new valve
  9. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    How long do these valves last? - and is there no risk that it leaks from the handle? And it doesn't leak from the valve - but when I shut it off the other day - it did leak a very small amount of water - so the normal operation is OK - but the shut off is not 100%.
  10. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    If ya don't mind getting wet, shut off that valve, cut the pipe coming out of the top. Get a new threaded 3/4" ball valve and put pipe dope on the threads and open it. Spin the old valve off, spin the new valve on, as soon as one thread is caught, close the valve and wrench it on tight. Then you can do whatever else needs to be done.
  11. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    The valve may be tight to the wall -- would have to bend the tubing outward a bit to get clearance to spin the valve.
    Rather than getting wet, I might be tempted to try to form an ice plug using a couple of bags of dry ice and ethanol around the pipe half way between the floor and valve. I have no experience with professional ice-plug gear, bit it doesn't look *that* complicated.
    I bet that even with the street valve off there will be some small amount of flow, making sweating a bit hard.
    In our town it's $70 per visit and usually you're talking about one visit to cut off the water, and a separate one to turn it back on. I understand you have to know the city worker pretty well and do some slick talking to get her to hang around for 20 mins while you do your work.
  12. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Replacing Valve
    If you know where the access point is why don't you shut off the water yourself? I won't tell.;)
  13. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Vashon, Washington
    twenty bucks cash usually will do the trick.
Similar Threads: Ball valves
Plumbing Forum, Professional & DIY Advice Welding PVC ball valves Jun 15, 2016
Plumbing Forum, Professional & DIY Advice PEX ball valves - Lead vs. Lead Free Mar 31, 2015
Plumbing Forum, Professional & DIY Advice Can all brass full port ball valves be used for hot water? Sep 20, 2012
Plumbing Forum, Professional & DIY Advice Red & White 1/4 Turn Ball Valves STILL OK to use? Jan 30, 2012
Plumbing Forum, Professional & DIY Advice Ball Valves - Forged Brass vs Forged Bronze Jun 11, 2011
