Ball Valve vs. Gate Valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Don Zorn, Feb 6, 2005.
  1. Don Zorn
    Don Zorn New Member
    Jan 9, 2005
    Alberta
    This is general question on which type of valve is more reliable.
    On the advice of a plumbing associate at my local HD, I soldered a "sweat type" ball valve on the 3/4" cold water supply to my hot water heater. After turning on the water I noticed a small pin hole leak in the valve itself where the two halves of the valve are threaded together. About one drip every 3-4 minutes. I plan to replace the valve. :(
    A similar thing happened on a 1/2" sweat type ball valve on a water facet to a hose located in my garage - the valve started leaking at the threaded joint after about 6 months of service. I replaced it with a standard gate type valve.
    The local HD pushes the ball valve as a better choice than the gate type valve. In my very limited experience with ball valves, both times they have failed. My question for the professional plumbers with years of experience is this. Are ball valves inherently less reliable than gate valves? Or does HD just stock cheap ball valves? What would you install on the cold water supply to a hot water heater?
    Thanks in advance for your advice and opinions. :)
    Don
  2. hj
    valves
    Yes, HD usually sells on the basis of price not quality. I have never had a ball valve leak at that joint. And yes they are inherently better than gate valves, especially the gate valves you would get at HD or similar. Are you overheating the valve when you install it. That could cause uneven expansion and might start a leak at that joint.
  4. Don Zorn
    Don Zorn New Member
    Jan 9, 2005
    Alberta
    I don't think I overheated the valve when soldering it - but who knows - maybe I am. I did open the valve when soldering as recommended by the manufacturer and tried to apply the heat evenly around the valve/pipe before applying solder.
    Any tips on what I could do differently next time around? :)
    Don
  5. hj
    valve
    Buy a better valve and then apply just enough heat to melt the solder so it flows properly.
Similar Threads: Ball Valve
Plumbing Forum, Professional & DIY Advice Replace 2 inch x3 and one 2 1/2 to ball valve tips Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Welding PVC ball valves Jun 15, 2016
Plumbing Forum, Professional & DIY Advice New Sharkbite 3/4" ball valve leaks Feb 14, 2016
Plumbing Forum, Professional & DIY Advice Cheap 1/4 turn ball valve - direction of off/on? Feb 13, 2016
Plumbing Forum, Professional & DIY Advice Any hints/tips/tricks to closing a "stuck" quarter turn ball valve? Feb 10, 2016
