Ball Valve questions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by John28, Jun 24, 2013.
  1. John28
    John28 Member
    Mar 17, 2013
    PA
    While I'm in the vacinty of replumbing my washer, I'm also replacing 1 shutoff to an outside spigot, and 2 shutoffs to the laundry tub.
    1.The shutoff for the outside spigot is in a run between an elbow and Tee. Would it be acceptable to buy the threaded type ball valve, then also buy male threaded copper fittings, then sweat the sections of copper on each male fitting, then once cool, wrench on to each end of ball valve with Teflon tape applied. Where now I have a valve with two tail pieces and can sweat these at the elbow and tee, with no fear of overheating the teflon around the steel ball valve? I realize they have direct sweat ball valves, but is this a good way for a rookie to go? I have sweated copper pipes, but just don't have the expierence to control proper heat.
    2. Laundry tub feeds below, where I'm wanting 2 shutoffs also. I thought of the angle compression type valve,but just recently replaced one on my kitchen sink that would not shut off, so decided maybe staight ball valves here also? Main issue is I want good volume to this sink, and do not want to reduce from the shutoffs to 3/8in. If I used the treaded ball valves here, could I run an 1/2 nipple in the outlet and supply it with 1/2 stainless braided lines? Thanks
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    You can get copper to copper ball valves no need for the adapters.
  4. John28
    John28 Member
    Mar 17, 2013
    PA
    I realize that, did you read the questions?
  5. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Sure, it will work. The down side is it will cost more money and introduces more places to leak.
  6. John28
    John28 Member
    Mar 17, 2013
    PA
    The price of a couple fittings is nill. My thinking was, if this could keep a novice sweater from destroying the valve, I'd actually save money? And I don't think there'd be much concern of a threaded joint that's wrenched leaking?
  7. speede541
    speede541 Member
    May 1, 2010
    Oakland
    From one novice sweater to another, I've popped a seal on one (3/4" and using mapp gas), and had a pinhole leak in another (1/2" -- and probably because I was being too cautious i.e. nervous in a tight space). But I've sweated maybe a dozen others without a problem.
    Wet rag wrapped around the open ball valve, apply the flame mostly to the pipe not the valve, and apply the heat just long enough to get the solder flowing. I'm much more comfortable with that in my wall vs. risking a dripping threaded connection. Also don't cut your pipe to length until after you sweat the connection to there's more material to wick the heat away from the valve body.
    Even if you blow one, it's probably worth the expense just to be comfortable with the process and see that it's not difficult.
  8. Terry
    Aug 17, 2004
    That's not how people that do this for a living think.
    The fewer fittings the better. Especially for a novice.
    Buy the sweat ball valve, and solder it away from the wall. You may want to remove the handle while you are at it, and replace it after it has been soldered.
    The brass will need to be heated, as well as the pipe.
    When that is done, Then bring it over to the wall and finish installing. Either 90's our couplings.
    I like compression stops at the wall for a washer or laundry tray.
    The only difference between 3/8" and 1/2" braided supplies are the nuts on the end. So pick your nut sizing and buy the shutoff to match.
  9. John28
    John28 Member
    Mar 17, 2013
    PA
    Do you know who makes the compression 1/4 turn stainless ball valve and stainless stem type? I thought they exist, but not sure? I just know I had the compression type for the kitchen shut offs, and the one would not shut off, they had teflon stems and were regular shut offs, just don't want these type again.
    And for compression type fittings, are they only rated for type M copper line?
    And for braided flex lines I realize there are 3/8 and 1/2 connections, but thought maybe some 1/2 might have a bigger I.D. within the line for better volume? Not sure though? Thanks
Similar Threads: Ball Valve
Plumbing Forum, Professional & DIY Advice Ball valve fp sillcock Wednesday at 11:28 AM
Plumbing Forum, Professional & DIY Advice Replace 2 inch x3 and one 2 1/2 to ball valve tips Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Welding PVC ball valves Jun 15, 2016
Plumbing Forum, Professional & DIY Advice New Sharkbite 3/4" ball valve leaks Feb 14, 2016
Plumbing Forum, Professional & DIY Advice Cheap 1/4 turn ball valve - direction of off/on? Feb 13, 2016
