Bad tub/shower valve?
Discussion in 'Shower & Bathtub Forum & Blog' started by WKB, Dec 13, 2004.
  1. WKB
    WKB New Member
    Dec 13, 2004
    Hello all. We're having problems with the flow in our main upstairs bathroom, I've measured it at under 2.5 gpm at both the faucet and shower spout with the head removed. We're plumbed with copper to the fixture (an older Delta model, maybe 80s by the look of it) and, while I haven't checked the house pressure (how would one do that, exactly?), we are seeing significantly higher flow rates at other faucets on the same level of the house. Am I right in thinking this likely suggests a blockage or buildup in the tub/shower valve, or could there be another culprit? And what would be my best option to try and take care of a bad valve? Happily, it's is easily reachable through an access panel if it has to be replaced. Thanks.
Similar Threads: tub/shower valve
Shower & Bathtub Forum & Blog Tub/shower valve replacement, Galvanized to PEX? Today at 1:05 PM
Shower & Bathtub Forum & Blog Delta tub/shower valve leak Feb 24, 2016
Shower & Bathtub Forum & Blog The right diverter valve for a tricky tub/shower combo Feb 23, 2015
Shower & Bathtub Forum & Blog How do you identify what Moen Posi-temp tub/shower valve you have? Jun 28, 2014
Shower & Bathtub Forum & Blog Costs of replacing Tub/Shower Valve Jun 22, 2014
