bad ground & electricity charges?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by darque, Oct 21, 2010.
  1. darque
    darque New Member
    Oct 20, 2010
    orange county california
    could electricity "leak" in a home through badly ground pipes copper or other metal (?)
    hypothetical~ if my copper pipes were not grounded properly causing corrosion to the water heater would that in any way use more electricity increasing the monthly kilowatt usage?
    just wondering.
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Galvanic corrosion uses DC. Your elec. meter does/should not respond to DC.
    Even if it did the corrosion is caused by a DC current loop that doesn't add or subtract from your household AC usage.
    But, in principle, you could test this.
  4. zorka
    zorka New Member
    Oct 20, 2010
    Canada
    No, electricty would not leak in the way that you described (i.e. on a continuous basis).
  5. hj
    If it did you would be in danger of electrocution EVERY time you touched a faucet or metal sink. I was testing a customer's system one time with a "TicTracer" which responded to electrical currents. When I went past their refrigerator, it "lit up". The reefer housing was "live" and the only thing that prevented them from shocks was that there was no plumbing nearby that they could touch at the same time they were at the refrigerator.
  6. darque
    darque New Member
    Oct 20, 2010
    ok great thank you.
Similar Threads: ground electricity
Plumbing Forum, Professional & DIY Advice Running underground power & water lines Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Above Ground, Outdoor Sewage Pump System? Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Pipe leak at water shut off or ground water? Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Copper to PEX-A Transition Underground Jun 27, 2016
Plumbing Forum, Professional & DIY Advice Leaking underground 2" PVC water line Jun 27, 2016
