Mad Plumber
Mad Skills
I assume we have a bad foot valve at our summer home. About 2 years ago, after being gone for a week with the power off, we would lose our prime. So I started leaving the pump on, so when the pressure dropped it would re-charge itself. But recently when I arrived there, the pump was running but no water in the system. I assume that the foot valve has gradually gotten worse to the point that it doesn't hold water at all. If it is a bad foot valve, how do I get it out?
The pump is in the basement. Two lines from the pump converge through a fitting into a 2" pipe that goes through the basement wall. There is a 2" pipe sticking out of the ground about 4 feet with a cap on it. Inside that 2" pipe there is what appears to be a 1" pipe that must be attached to some type of "fitless adapter".
I'm assuming that I can use that 1" pipe to pull the guts out of the 2" casing. Is that correct? What do I need to watch for?
Thanks for any help.
Look4info 6/5/2008
Look4info 6/5/2008
