bad connection?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by creepyoldguy, Feb 2, 2009.
  1. creepyoldguy
    creepyoldguy New Member
    Jan 2, 2008
    I'm putting in a shower with a 3" drain and noticed that the 90 degree fitting that goes up to the drain was not connected all the way in to the drain pipe. There is about a 1/2" gap between the lip of the fitting and the end of the pipe that is inserted inside of it. There is probably a little over an inch of pipe that is inside the actual fitting, and the connection seems strong- doesn't move or anything. will this become a problem? Should i cut the pipe out and refit?
    Thanks,
    S
Similar Threads: connection
Plumbing Forum, Professional & DIY Advice Leaking Connection - Help Please! Feb 1, 2017
Plumbing Forum, Professional & DIY Advice New connection to main house line Jul 30, 2016
Plumbing Forum, Professional & DIY Advice NPS (Straight Thread) Fitting OK for Hidden Connections? Apr 5, 2016
Plumbing Forum, Professional & DIY Advice CPVC to brass connector leak, correct connection? Mar 4, 2016
Plumbing Forum, Professional & DIY Advice Are Zurn Qickclamps a reliable pex connection? Feb 10, 2016
