Bacteria Issues - New Well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by chuck b, Feb 3, 2012.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Just had a new well drilled for my cottage located in Northern Michigan. Was on a shared well previously. Used the continuous variable speed power pump and am happy with that. However, after several unsuccessful water sample tests, we are getting a no pass on the bacteria content of the water. The reputable well digger said he will "bomb" the well shaft with chlorine, then retest. The water is off to the cottage having been blown out before the cold winter. I am concerned that "even if it passes as a result of the chlorine, would that not just be a false negative, so when the chlorine is flushed out the bacteria could return?" How should I handle this. The well was dug some 89 feet, the 50' adjacent septic systems isolation distances were honored as I pulled a permit, and the other cottages along the beach with wells dug at this level have had no problems. Thanks.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    "Bacteria" is a general term that doesn't mean much.
    Fecal coli-form now would be telling us something.
    If the well water is contaminated, then the piping is also. The entire system must be treated with chlorine.
    If the driller contaminated the well, a proper and complete chlorine treatment should fix it.
    If the water table is contaminated from another source, the problem will be likely to return.
  4. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Most bad tests are a false positive.
    It's easy to get a bad test, it's hard to get a good one.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    If he is not recirculating the water down the well head, its all for nothing.
  6. Mikei16
    Mikei16 New Member
    Feb 12, 2012
    Dutchess County
    If he is not recirculating the water down the well head, its all for nothing. ? What is the benefit of recirculating the water down the well head ?? I am re-using an older well that has not been used for sometime.
    Mike
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The bacteria is/can be living on the wet walls of the bore hole and the casing. The chlorine solution should be recirculated to coat all surfaces inside the well. After the contact time has expired, the re-circulation should continue while the well is being pumped off to clean the well.
  8. ballvalve
    Dec 28, 2009
    Not to mention the bacteria that came in with the new equipment. And maybe a few dog turds.
Similar Threads: Bacteria Issues
Pumps and Tanks Well Forum & Blog. Water is life. what is the best bacteria additive to septic system. Sep 2, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Sediment and Bacteria help! Aug 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Appreciate advice on replacing bacteria filled aerator Feb 3, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Poor Water Quality: Is This a Sign of Iron Bacteria? If Not, What Is It? Dec 6, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Advice for well that tests positive for coliform bacteria Jul 30, 2012
