backwater valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by maddon, Dec 31, 2010.
  1. maddon
    maddon New Member
    Dec 31, 2010
    New brunswick ca
    am i allowed to place a valve behind a grey water drain for upstairsdrain
    adding new bathroom downstairs . (split entrance, sewage drain on basement floor)
    putting false floor to run plumbing would like to be sure??
  2. hj
    I have no idea what you are asking about. But normally, the backwater valve would be for the LOWER level fixtures and the upper level would connect downstream from it so they would work normally even if the backwater valve was closed because of a flood condition. An entire bathroom is NOT a "gray water drain" system.
  4. maddon
    maddon New Member
    Dec 31, 2010
    New brunswick ca
    down spout from mainfloor bathroom is in front BWV,
    but i think you answered my question
    Thanks
Similar Threads: backwater valve
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Rough plumbing layout w/ backwater check valve. May 21, 2016
Plumbing Forum, Professional & DIY Advice Backwater Valve Identification Jan 27, 2016
Plumbing Forum, Professional & DIY Advice Negative Pressure in Drain, Backwater Valve, Zero Slope Nov 27, 2015
Plumbing Forum, Professional & DIY Advice AAV upstream of backwater valve? Nov 21, 2014
