Backwash Filtration System
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by sparker, Jan 5, 2009.
  1. sparker
    sparker New Member
    Aug 18, 2008
    Hey guys,
    I was wondering if anyone would recommend a multimedia backwash filter to treat colloidal clay in a private well? I installed a ge last march but I have to replace the filter (25 micron) every three weeks. Thanks
  2. Gary Slusser
    Retired
    If you draw a glass of water, I take it is dirty, right?
    If it's dirty and you set it down, how long does it take to clear?
    What color is the dirt?
    How much iron is in the water?
    What is the pH?
  4. sparker
    sparker New Member
    Aug 18, 2008
    When I draw from a tap the water comes out cloudy with a slight orangish hue, settling after about 4-5 min. Last year I had the water tested. Findings included presence of iron, sediments, a pH slightly on the acidic side. Toilet tanks are stained orange, as well as the inside of my dishwasher. If shower stalls aren't cleaned weekly they stain as well. We noticed this our first night in the house, despite the previous owner not disclosing these problems. Well was constructed in 2001. Six inch casing at a depth of 200 ft. So I assumed about 170 ft of water somewhere in the neighborhood of 300 gal. About a month ago I shocked using 2 gal of bleach, but that hasn't seemed to help much. Thanks for your input.
  5. Gary Slusser
    Retired
    Then you have an iron problem, not "colloidal clay".
    Exactly how much iron?
    What is the pH exactly?
    Exactly how much hardness is in the water?
  6. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    You need to get a potability test from a local certified lab. Once you get the results you should post them and that way you can get suggestions on how to properly treat your water. Take the sample before any water filters so get a raw water analysis.
    sammy
    www.tylerwellandpump.com
  7. Gary Slusser
    Retired
    Anyone that does iron, pH and hardness tests is good enough accuracy. There is no reason to spend a bunch of money to a certified lab. Pump and plumbing supply houses, Sears, county extension offices etc. will usually do these tests for a few bucks or free.
    Or buy a test kit and do them yourself.
  8. sammyhydro11
    Dec 20, 2006
    Massachusetts
    yeah forget everything else in a potability test. God what was i thinking? Coliform, ecol i,nitrates,turbidity,sodium,manganese,tds, etc. Screw all of that! especially the nitrates! I just hope the guy doesn't have any new borns or younger children. But what does that matter? He's just a naive customer that has no clue about water treatment. Gary you need to keep in mind that people actually drink well water. God forbid someone gives these people good advice!
    sammy
  9. sparker
    sparker New Member
    Aug 18, 2008
    Thanks. I'll get the numbers and post back.
    Scott
  10. sparker
    sparker New Member
    Aug 18, 2008
    Here's what I got:
    Iron 3 PPM
    Chlorine 0 PPM
    PH 5
    Hardness 50 PPM
    Alkalinity 0
    Copper 3 PPM
    Nitrate 0 PPM
    Nitrite 0 PPM
    I think the pH and copper are what concern me most.
  11. Gary Slusser
    Retired
    You have extremely acidic water, high iron and copper. The copper will go away IF you treat the low pH unless you have copper tubing to or from the pressure tank and then to an acid neutralizing filter or solution filter.
    If you use a backwashed sacrificial mineral AN filter, it will raise the pH and that will cause some of the iron to be oxidized and prevent the copper that is being added to your water now and also add a fair amount of hardness to the water. So you probably would want a water softener.
    If you used a solution feeder, the water may be not so 'nice' because of having to use so much soda ash. And IMO solution feeders are a PIA and require a lot of baby sitting and tend to never really work well; especially for pH control.
  12. sparker
    sparker New Member
    Aug 18, 2008
    Thanks Gary. I've been researching a few softeners. Is there a particular brand you would recommend?
    In all likelihood it will have to be installed in the attic, near the water heater, as there is only about 24" of clearance in the crawl space. Thanks for the input!
  13. Gary Slusser
    Retired
    Well yes I can, you should buy it from me and we'll call it Gary's Superduper no name Water Softener but... you also need an AN filter.
    I've had other customers install in an attic but it would scare me to death to have a water heater and softener etc. in an attic.
Similar Threads: Backwash Filtration
Pumps and Tanks Well Forum & Blog. Water is life. Only Pressure Tank after Backwashing Filter? Jul 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Fine Sediment Clogging 1-Micron Filters - Will Backwashing Help? Jun 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Iron filter backwash line May 7, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Replacing backwash valve on acid neutralizer Sep 1, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Well filtration - thoughts and recommendations? Dec 22, 2016
