backup wood boiler wont shut off
Discussion in 'Boiler Forum' started by wilty74, Dec 13, 2009.
  1. wilty74
    wilty74 New Member
    Dec 13, 2009
    galesburg,il
    My wood boiler is a backup to my gas boiler the gas boiler is working fine but when the wood boiler is up the temp the pump will not shut off was working fine just all the sudden quite shutting off any help is appreciated thanks
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Sounds like your over heating the wood boiler. The circulator keeps running to stop the boiler from over heating. The boiler temperature should not be any hotter then 180. Most wood boilers are wired so the circulator will run when the temperature exceeds 180 if the thermostat is calling or not.
    John
Similar Threads: backup wood
Boiler Forum Gas Boiler Backup for Thermal Tank Nov 18, 2015
Boiler Forum Buderus set up, wood boiler. Nov 21, 2015
Boiler Forum I want to build wooden baseboard covers. Drawbacks?Are metal designed to throw heat? Apr 15, 2014
Boiler Forum out with the LP boiler , in with the P&M wood boiler Dec 19, 2013
Boiler Forum HELP...Integrating Outdoor Wood Furnace with indoor Propane Boiler Sep 28, 2013
