Backflow device question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chetwynd, Dec 28, 2006.
  1. chetwynd
    chetwynd New Member
    Jul 27, 2005
    California
    Hi,
    My girlfriend works for a property management company, and the backflow devices on water lines at their properties keep getting ripped off for scrap metal (stupid meth addicts). Anyway, she needs to find something other than copper or brass or whatever it is.
    Do they make anything else? Any ideas?
  2. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    How about putting cages around them? With booby traps and bungi stakes!
  4. Rancher
    Rancher Guest
    Unless they've changed them those backflow devices have a stainless steel set screw that you are "supposed" to screw into the hose bib to permantly secure them, then the head of the set screw is broken off to keep it from being removed.
    Rancher
  5. hj
    backflow devices
    They are referring to the large ones on the water mains at the meters. You can get stainless steel ones, but they will cost as much as two or three of the brass ones. Metal cages with locks on them are the usual security devices.
  6. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Yeah... then the theives can take the cage and lock in for scrap too! Bolt cutters work wonders.
  7. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Ames makes a good one. stainless steel body and easy to service.
  8. hj
    cage
    In the first place the cages are bolted to a concrete pad in the ground, which would make them more difficult, but not impossible to remove. But since the thieves have to be in and out in a matter of minutes removing the bolts would normally induce them to find an easier one to steal. Second, cutting the lock only opens the access door. Getting to the connections usually requires that the cage be removed, or spending a lot more time trying to access them. Again, time they really may not have.
Similar Threads: Backflow device
Plumbing Forum, Professional & DIY Advice Backflow device for bidet. Jun 14, 2013
Plumbing Forum, Professional & DIY Advice Most Reliable RPP Backflow Model? Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Concerning backflow [water contamination] issue, advice needed Oct 16, 2016
Plumbing Forum, Professional & DIY Advice There's a hose bib before the RPZ and PRV with no backflow prevention... Jun 11, 2016
