Backer board
Discussion in 'Shower & Bathtub Forum & Blog' started by tulegit, Sep 18, 2006.
  1. tulegit
    tulegit New Member
    Sep 18, 2006
    I'm replacing my bath/shower walls. The surrounding drywall is 5/8" and the thickest backer board that Home Depot or Lowes sells is 1/2". What am I supposed to do to accomadate the 1/8' difference?
    This is my first major remodel and I'm kinda stuck on this issue right now.
    Thanks,
  2. jadnashua
    You can buy some slats or shims...put them behind the cbu to get it out to the same thickness as the drywall. Make sure you use a vapor barrier behind it as well. If you decide to use roofing felt rather than plastic for your vapor barrier, you could put up several layers to give you the thickness you want. If you have to buy a roll, might as well use up some of it.
  4. George R
    George R New Member
    Mar 7, 2005
    Central Illinois
    Around here you can buy a bundle of "drywall shims". They are 1 1/2" wide x 40" long and 0.080" thickness They come in bundles of 50 and are made from stiff cardboard.
    I've never seen them at Lowes or HD, but M*nards carries them (put an e for the *). About $5/bundle.
    They look like this
    http://www.recycled-packaging.com/drywall-shims.htm
    Or do like Jim said and use builders felt. However, I like the drywall shims better because the relative "thinness" of the spacers (approx 3/32") allow you to get a pretty close match to the buildup you need by stacking as many as you need, and they are the right width with no cutting required.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Why not use 3/8" plywood then-1/4" CBU? Don't forget the vapor barrier.
  6. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Double the 1/4" backerboard by using strips of itself as shims over the studs. Try it and see if you get more than 1/2'. The Hardi company used to sell only 1/4" Hardiboard and that was the method they used to recommend to build up the thickness. Costs less too. A lot less.
    You'll add more thickness when you put your vapor barrier on too.:)
    The CBU is only nominally 1/4". The batch you buy could be a lot thicker. That happens.
    Tulegit, are you planning on tiling these walls?
    david
  7. tulegit
    tulegit New Member
    Sep 18, 2006
    If i double the 1/4" backer board, it would only be 1/2" and I need it to be 5/8".
    I guess added 3/8" plywood or drywall and then 1/4" backerboard would work out...although it would cost more.
    Yes, I plan on tiling or adding cultured marble.
  8. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    Use 5/8" drywall and put a Kerdi membrane on it.
  9. tulegit
    tulegit New Member
    Sep 18, 2006
    that sounds interesting. I'll have to look into that. thanks.
  10. jadnashua
    Kerdi is a tileable membrane made by www.schluter.com. Check out their website for a small video to see someone installing it. ALso, check out www.johnbridge.com about tiling.
  11. geniescience
    Nov 27, 2005
    ditto
    Did I mentino that
    "The CBU is only nominally 1/4". The batch you buy could be a lot thicker."
    So if you are interested in a backerboard wall, look at the thinnest CBU board and see if you can use it by shimming itself with itself.
    david
  12. Verdeboy
    Jun 12, 2006
    Boy, they used enough mortar installing that Kerdi to build a small house!:rolleyes:
  13. Mikey
    Nov 8, 2005
    Consumer
    Pretty tiny notches in the trowel, though. I don't think it would bring the walls down...
  14. jadnashua
    The mortar layer is really quite thin. The stuff works...
  15. kcchiu
    kcchiu New Member
    Jun 26, 2010
    NJ
    Kerdi board
    Greeting,
    Does anyone know where to buy Kerdi board ?
    I need to rebuild my shower room and I am planning to use it.
    I know there is Wedi board too but nowhere in Internet sell it neither.
    Thank you
  16. jadnashua
    Kerdi board has it place, but it's not that big a deal to just use the membrane itself. It produces the same result, although might take a little longer. Kerdi works fine over drywall for a shower - it is the preferred substrate. It works because the Kerdi membrane makes the drywall all be on the dry side...it is 100% waterproof.
    Check out www.johnbridge.com for help with your tiling and the shower.
Similar Threads: Backer board
Shower & Bathtub Forum & Blog Waterproofing bathtub cement backer board Jul 6, 2015
Shower & Bathtub Forum & Blog Backerboard over Insulation May 26, 2015
Shower & Bathtub Forum & Blog Leave old tile that's straight on concrete backerboard or insert shower walls? Jan 22, 2015
Shower & Bathtub Forum & Blog Different kinds of backer board for shower Jun 5, 2014
Shower & Bathtub Forum & Blog Hardibacker board- tub,shower wall questions Jan 29, 2014
