Back Water Valve installation requirements
Discussion in 'Canadian Plumbing Code Questions' started by Mach123, Oct 15, 2016.
  1. Mach123
    Mach123 New Member
    Oct 15, 2016
    Alberta
    Hi Guys
    I'm new on forum and like to see if I can get an answer on my issue.
    I am installing a back water valve in a new construction home in bc Canada and the sewer line is a 4 in and pops up at a 45 just inside garage door. So my question is, can I continue the line to the outer edge of garage and install it, then come up above grade to rest of home. Second thing is. I can not find any info on if it needs to be so many inches away from a 45 before or after the unit or if stack needs to be so far away from unit. Thx
  2. Mach123
    Mach123 New Member
    Oct 15, 2016
    Alberta
    Wow, I'm shocked no one has an answer. This has been the first time it has taken so long to get an answer, or non at all.
    Unless I stump everyone, lol
  4. Wrenched
    Wrenched In the Trades
    Apr 20, 2011
    Vancouver, BC
    Hey Mach 123, a little late, but here goes:
    You're asking a question in the code section (a less busy part of the site), about canadian code (also less common visitors to the site).
    There just aren't a lot of people here to answer your question.
    Your best bet to contact your local plumbing inspectors and run things by them.
    Otherwise, pictures and location information might help the forum help you.
    First off I'll say sanitary BWVs are uncommon in my part of B.C. with only New West. asking for them in the lower mainland.
    Secondly, the only mention in the NPC is in section 2.4.6.4, essentially laying out that sanitary valves must be full-port normally open valves, and that combined systems(which are not allowed in new builds) require protection against sewage back-up on the subsoil drainage side.
    Thirdly, the only manufacturers I know of are Mainline and Inflotrolix (Aqua-protec), of which Mainline has a 99%+ market share. They can answer specific questions about their products.
    Hopefully your questions have already been answered elsewhere. If so it'd be great to hear back, if not, post some pics, we'll see what fits your situation.
Similar Threads: Water Valve
Canadian Plumbing Code Questions Canada. Hot Water Tank Change Out. Gas flex? Oct 15, 2016
Canadian Plumbing Code Questions Should I be worried about a dent in the water heater? Aug 16, 2015
Canadian Plumbing Code Questions Water Heater Code Question Nov 8, 2014
Canadian Plumbing Code Questions water pipes below electrical panel Oct 6, 2014
Canadian Plumbing Code Questions Use of Copper Potable Water Pipe Underground Apr 29, 2014
